Saltar al contenido principal
MacBook Unibody Model A1278 Front Display Glass Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Traduciendo paso 10
Inglés
Español
Paso 10
MacBook Unibody Model A1278 Front Display Glass Replacement: paso 0, imagen 1 de 3 MacBook Unibody Model A1278 Front Display Glass Replacement: paso 0, imagen 2 de 3 MacBook Unibody Model A1278 Front Display Glass Replacement: paso 0, imagen 3 de 3
  • During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
  • If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
  • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
  • Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
  • Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
  • Reapply the piece of tape covering the AirPort & iSight data cable socket.
Insertar traducción aquí
