Saltar al contenido principal
Dell Inspiron 15 Ram (Memory Module) Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Dell Inspiron 15 Ram (Memory Module) Replacement: paso 0, imagen 1 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement: paso 0, imagen 2 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement: paso 0, imagen 3 de 3
  • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
  • Using the plastic opening tool, pry the base cover from the base.
  • Slide the base cover towards you and remove it from the base. Put it aside.
Insertar traducción aquí
