Saltar al contenido principal
Dell Inspiron 15 Ram (Memory Module) Replacement
Qué necesitas
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: paso 2, imagen 1 de 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): paso 3, imagen 1 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): paso 3, imagen 2 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): paso 3, imagen 3 de 3
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: paso 4, imagen 1 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement: paso 4, imagen 2 de 3 Dell Inspiron 15 Ram (Memory Module) Replacement: paso 4, imagen 3 de 3
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
Conclusión
4 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 21
Ultimos 30 días: 41
Todo El Tiempo: 6,728
