Saltar al contenido principal
MacBook Core Duo Optical Drive Bezel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 4
MacBook Core Duo Optical Drive Bezel Replacement: paso 0, imagen 1 de 2 MacBook Core Duo Optical Drive Bezel Replacement: paso 0, imagen 2 de 2
  • Insert the flat end of a spudger between the optical drive bezel and the plastic lower case.
  • Gently pry the optical drive bezel away from the adhesive securing it to the lower case enough to lift the mounting ear near the hard drive connector above the metal framework.
  • Lift the optical drive bezel enough to clear the metal framework and continue separating it from the lower case with your spudger.
Insertar traducción aquí
