Saltar al contenido principal
Canon PowerShot S230 Motherboard Replacement
Inglés
Español
Paso 2
Canon PowerShot S230 Motherboard Replacement: paso 0, imagen 1 de 3 Canon PowerShot S230 Motherboard Replacement: paso 0, imagen 2 de 3 Canon PowerShot S230 Motherboard Replacement: paso 0, imagen 3 de 3
  • The motherboard can be damaged easily and must be treated with care. Try to avoid removing ribbon cables with your fingers, since motherboards are extremely sensitive to static discharge. Use a spudger or plastic opening tool to lift any flaps or tabs or to pry connectors straight off their sockets on the motherboard.
  • Before the motherboard can be removed, several ribbon cables must be disconnected from their respective ports. A few of the ribbon cables are held in place by locking ZIF connectors, which you must release before removing the cables. Removing each ribbon cable may require a gentle tug.
  • First, release the ZIF connector securing the ribbon cable in the bottom left corner of the motherboard. To do this, insert the flat end of a spudger under the connector's dark brown flap and gently wedge the flap open.
Insertar traducción aquí
