Saltar al contenido principal
Canon PowerShot SX50 HS Motherboard Replacement
Inglés
Español
Paso 3
Canon PowerShot SX50 HS Motherboard Replacement: paso 0, imagen 1 de 3 Canon PowerShot SX50 HS Motherboard Replacement: paso 0, imagen 2 de 3 Canon PowerShot SX50 HS Motherboard Replacement: paso 0, imagen 3 de 3
  • To remove the topmost wire ribbon on the I/O board, lift up the brown latch, and then carefully pull out the ribbon. You can use your fingers or the tweezers.
  • Remove the wire ribbon on the top left corner of the I/O board with the same process as the previous step.
  • Be careful when removing wire ribbons; they are very delicate.
Insertar traducción aquí
