Saltar al contenido principal
Dell OptiPlex GX260 CPU Replacement
Inglés
Holandés
Traduciendo paso 2
Paso 2
Dell OptiPlex GX260 CPU Replacement: paso 0, imagen 1 de 2 Dell OptiPlex GX260 CPU Replacement: paso 0, imagen 2 de 2
  • Carefully release the ZIF socket - push the lever backwards to release it from the hold down tab and lift it up and to the left until it stops (roughly 90 degrees).
  • Gently lift the CPU straight up and out of the socket. There should be no resistance.
  • The CPU will only fit into the ZIF socket in one orientation so take care when reinserting it. make sure that pin A1 is located correctly
  • Take care not to bend the pins on the CPU
Insertar traducción aquí
