Saltar al contenido principal
Canon Powershot A720 IS Lens Replacement
Inglés
Holandés
Paso 16
Canon Powershot A720 IS Lens Replacement: paso 0, imagen 1 de 3 Canon Powershot A720 IS Lens Replacement: paso 0, imagen 2 de 3 Canon Powershot A720 IS Lens Replacement: paso 0, imagen 3 de 3
  • Use the screwdriver to remove the three 3 mm Phillips screws from the lens metal frame.
  • Use the screwdriver to remove the two 3.5 mm Phillips screws from the lens metal frame.
  • Pull out the AV DC IN port on the right side of the camera.
  • Turn the camera over so the bottom is exposed to remove the 3 mm Phillips head screw to disassemble the battery housing unit from the camera.
Insertar traducción aquí
