Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 19 guías que incluyan este paso.
Inglés
Español
Paso 3
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
  • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
  • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Insertar traducción aquí
