Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 19 guías que incluyen este paso.
Traduciendo paso 4
Paso 4
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
