Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Power down your device. Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time.  For some a finger nail may be best. The case comes up quite high to the glass.
  • Power down your device.
  • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
  • Do not pry near the USB port at the base of the device as you may crack the rear panel.
Apaga el dispositivo.
Usa tu herramienta de apertura de plástico para calzar entre los rebordes alrededor de los lados del dispositivo. Haz palanca en cada lado, uno a la vez.
No te acerques al puerto USB de la base del dispositivo, ya que puedes romper el panel trasero.
[* black] Power down your device.
-[* black] Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time.
+[* black] Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
[* icon_caution] Do not pry near the USB port at the base of the device as you may crack the rear panel.
