Saltar al contenido principal
Toshiba Satellite 2435-S255 Monitor Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Toshiba Satellite 2435-S255 Monitor Replacement, Unscrew the Cover: paso 0, imagen 1 de 2 Toshiba Satellite 2435-S255 Monitor Replacement, Unscrew the Cover: paso 0, imagen 2 de 2
Unscrew the Cover
  • Unscrew the front of the casing by unscrewing the two 8mm screws indicated. We will be using a PH00 screwdriver for every screw in this guide.
  • You may or may not have to take the screw covers off beforehand. They’re easy to remove; all you have to do is pry them off. We used tweezers, but anything thin enough should work. Then, just unscrew the underlying screws.
Insertar traducción aquí
