Saltar al contenido principal
Sustitución de la RAM del Toshiba Satellite A215-S7425
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Toshiba Satellite A215-S7425 RAM Replacement: paso 0, imagen 1 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 0, imagen 2 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 0, imagen 3 de 3
  • Locate 2 metal pinchers on either side of the 1st RAM stick.
  • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
  • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
  • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
Localiza 2 pinzas de metal a cada lado de la primera memoria RAM.
Usa un dedo de cada mano para empujar las 2 pinzas simultáneamente alejándolas de la memoria RAM y hacia el exterior de la caja.
La memoria RAM se levantará automáticamente. Saca suavemente la memoria RAM con una mano.
Se recomienda el uso de una muñequera antiestática mientras se trabaja con la RAM para evitar que las descargas electrostáticas (ESD) dañen la RAM.
[* black] Locate 2 metal pinchers on either side of the 1st RAM stick.
[* black] Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
[* black] The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
-[* icon_caution] The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
+[* icon_caution] The use of a [product|IF145-071|anti-static wrist strap] while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
