Saltar al contenido principal
Disassembling Canon PowerShot SX200 IS
Inglés
Holandés
Paso 11
Disassembling Canon PowerShot SX200 IS: paso 0, imagen 1 de 3 Disassembling Canon PowerShot SX200 IS: paso 0, imagen 2 de 3 Disassembling Canon PowerShot SX200 IS: paso 0, imagen 3 de 3
  • Remove a screw from the bottom of the LCD frame.
  • Remove 5 screws retaining the LCD frame. Note that one is recessed at the top right hand corner. This is a very slightly different size - keep it separate from the other 4.
  • Note that one or two of these screws can initially be hard to turn. Be sure to apply sufficient downward pressure to prevent the screwdriver slipping as it will be impossible to remove a screw if you burr the head.
  • Remove the LCD frame, and a supplementary piece of metal (3rd photo) on the bottom right hand side of the frame, which covers a pair of snap-on connectors and prevents them working loose. Note that on reassembly, it’s easy to forget this additional piece of metal.
  • If you simply need to access the sensor or the infrared filter, you only need remove the supplementary piece of metal. Then, follow instructions in the companion guide Canon PowerShot SX200 IS Lens Disassembly.
Insertar traducción aquí
