Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 6
Turn the camera with the lens facing down. Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened. Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
  • Turn the camera with the lens facing down.
  • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
  • Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
  • Carefully make pressure downwards on the opening tool so the cover can gradually open.
  • Keep making pressure and slowly slide the opening tool through all the gap.
  • There is one point when the cover will disassemble completely.
  • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
Insertar traducción aquí
