Saltar al contenido principal
Toshiba Satellite A105-S4011 Display Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Paso 2
Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 1 de 3 Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 2 de 3 Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 3 de 3
  • The next step is to remove the plastic from around the display. First you must remove the 5 screws found around the plastic part of the display (indicated in picture 1).
  • Note: There may be a rubber pieces covering the screws. You can just pry these off with your screwdriver or your fingernails.
  • After the screws are removed you can pry the plastic part off. This may require a bit of force, but be careful not to snap the plastic. Always start in one place and slowly lift around the screen.
Insertar traducción aquí
