Saltar al contenido principal
Toshiba Satellite A105-S4011 Display Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 1 de 3 Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 2 de 3 Toshiba Satellite A105-S4011 Display Replacement: paso 0, imagen 3 de 3
  • Now you need to detach the screen from the rest of the laptop. Start by removing the screws on the hinge (indicated in picture one).
  • After removing the screws look to the right side of the laptop. Remove the white wire in the channel found there. To do this you only need to move the wire around the plastic pieces holding it down.
  • You will also find a connector on the left side of the laptop (indicated in picture two in the square). Pull gently on it to detach it. You may now pull the display completely off.
  • The eyelet in the circle is a necessary grounding wire for the LCD, when you reattached the hinges to the base you will need to put a screw through this eyelet.
Insertar traducción aquí
