Saltar al contenido principal
PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement: paso 0, imagen 1 de 3 PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement: paso 0, imagen 2 de 3 PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement: paso 0, imagen 3 de 3
  • Insert the flat end of a spudger between the rear display bezel and the plastic rim attached to the front display bezel near the lower right corner of the display.
  • Do not try to insert the spudger between the front display bezel and its plastic surround.
  • While carefully prying the rear display bezel away from the display assembly, use a small flathead screwdriver to pry the small steel clip nearest the bottom right corner of the display away from the edge of the front display bezel.
  • Repeat the above procedure until you've released all the clips along the right side of the display.
Insertar traducción aquí
