Saltar al contenido principal
PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement: paso 0, imagen 1 de 2 PowerBook G4 Aluminum 17" 1-1.67 GHz Rear Display Bezel Replacement: paso 0, imagen 2 de 2
  • Remove the two 6.3 mm Phillips screws near the lower left and right corners of the display.
  • Removing these two screws may be difficult. It is helpful to open the display as much as possible for clearance to use a screwdriver. Also, a combination of #00 Phillips and small flathead screwdrivers along with a pair of tweezers may aid in removal.
Insertar traducción aquí
