Saltar al contenido principal
Xbox Series X 2TB Galaxy Black Chassis Removal
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Paso 3
Xbox Series X 2TB Galaxy Black Chassis Removal, Disconnect the power button cable: paso 0, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Chassis Removal, Disconnect the power button cable: paso 0, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Chassis Removal, Disconnect the power button cable: paso 0, imagen 3 de 3
  • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
  • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
  • Pull only on the pull tab, not the cable itself.
  • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
  • During reassembly, the cable should lightly "snap" into place when inserted.
Insertar traducción aquí
