Traduciendo paso 4
In order to understand the structure of the lamp I had to tackle the top part so the nut and bolt systems in the battery case could be explained. The handle was easily removed manually
The lid-like structure at the top supported the LED torch. The green centralised button visible is the tip of the torch. There is a button which releases the tip of the torch directly when pushed. The black plastic lid is separated easily and reveals the structural foundation of the torch.
The lid contained a small helical compression spring and a phillips round head pointed tip screw to support the torch ejection system. The source of the nuts and bolts were also present in the lid. The screws were long phillips round headed flat tips. These were removed using a phillips screwdriver.
The translucent plastic shell is easily removed once the screws are out of place.
Height: 150 mm
Width: 97 mm
Weight: 62 g
