Traduciendo paso 2
The device's base is the battery compartment, which is externally rubberised, contributing to the water-resistant nature of the lamp.
It also has 3 protrusion-like legs, which coupled with the friction from the rubber, allows for a good surface grip.
The base is designed to be easily twisted off, revealing the internal battery structure which sits within the grey shell. The internal structure of the battery case is made entirely of lightweight plastic and accommodates 3x D batteries, as per the manual.
7 screws of 2 different varieties were used to anchor the battery ports. A round headed, phillips pointed tip and a flat headed phillips pointed tip. These were removed using a phillips screwdriver.
Diameter: 100 mm
Height: 93 mm
Weight: 32 g
