Saltar al contenido principal
Inglés
Español
Paso 9
Another odd looking piece is the location of the power Amp IC. The smudge marks of the thermal past revealed that the board was loose and the the IC did not make contact with the heatsink The thread in the heatsink was partially stripped. Use a small jewelers screwdriver to wedge under the screw,while using a #2 Philips screwdriver to remove it.
  • Another odd looking piece is the location of the power Amp IC.
  • The smudge marks of the thermal past revealed that the board was loose and the the IC did not make contact with the heatsink
  • The thread in the heatsink was partially stripped. Use a small jewelers screwdriver to wedge under the screw,while using a #2 Philips screwdriver to remove it.
Insertar traducción aquí
