Saltar al contenido principal
Inglés
Español
Paso 10
Remove the connector from the PCB. Remove the IC PCB from the panel. The IC definitely shows some damage, most likely from overheating. Here is a close up of the damaged IC. It is a TDA2030A 18 W hi-fi amplier / 35 W audio driver
  • Remove the connector from the PCB.
  • Remove the IC PCB from the panel. The IC definitely shows some damage, most likely from overheating.
  • Here is a close up of the damaged IC. It is a TDA2030A 18 W hi-fi amplier / 35 W audio driver
Insertar traducción aquí
