Saltar al contenido principal
Opening Procedure
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Holandés
Paso 5
Opening Procedure: paso 0, imagen 1 de 2 Opening Procedure: paso 0, imagen 2 de 2
  • Wait one minute to give the adhesive a chance to release and present an opening gap.
  • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
  • For complete instructions on how to use a hair dryer, check out this guide.
  • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
  • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
  • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
  • Skip the next step.
Insertar traducción aquí
