Saltar al contenido principal
Xbox Series X Vervanging van het achterste paneel
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 27 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Xbox Series X Back Panel Replacement, Unclip the back panel: paso 0, imagen 1 de 3 Xbox Series X Back Panel Replacement, Unclip the back panel: paso 0, imagen 2 de 3 Xbox Series X Back Panel Replacement, Unclip the back panel: paso 0, imagen 3 de 3
  • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
  • Pry up the back panel to release it from the locking clips.
Steek het platte einde van je spudger in de opening tussen het achterste paneel en de behuizing, dichtbij de linkerzijde van de basis.
Hef je spudger op de behuizing en trek het achterste paneel aan de onderkant omhoog om deze uit de sluitklemmen los te maken.
[title] Unclip the back panel
[* black] Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
-[* black] Pivot the spudger on the shell and pull up on the bottom of the back panel to release it from the locking clips.
+[* black] Pry up the back panel to release it from the locking clips.
