Saltar al contenido principal
iMac 2009-2010 SSD Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 10
Paso 10
iMac 2009-2010 SSD Replacement: paso 0, imagen 1 de 3 iMac 2009-2010 SSD Replacement: paso 0, imagen 2 de 3 iMac 2009-2010 SSD Replacement: paso 0, imagen 3 de 3
  • If your motherboard has a socket for a hard drive temperature sensor, follow this step to plug the sensor wires in.
  • Find the connector on the motherboard labeled HD TMP or HDD TEMP.
  • If you have trouble locating it, trace the two-wire temperature cable you disconnected from the old hard drive.
  • If the previous temperature cable is still connected to the board here, disconnect and remove it. You will no longer need it.
  • Connect the temperature sensor's two-wire red-black cable to the motherboard plug labeled HD TMP or HDD TEMP.
  • The connector is keyed to fit in only one orientation. If it doesn't fit one way, rotate it 180° and try again.
  • Route the excess wire so it does not interfere with any other components.
Insertar traducción aquí
