Saltar al contenido principal
Desmontaje de Dell Vostro V13
Inglés
Español
Traduciendo paso 11
Paso 11
Dell Vostro V13 Disassembly: paso 0, imagen 1 de 1
  • Unscrew the four PH1 screws from the heatsink.
  • You may also need to remove the screw on the fan shroud.
  • Pull the heatsink and the fan upward to remove both.
Desenrosque los cuatro (4) tornillos del disipador de calor.
Desatornille el (1) tornillo del ventilador.
Tire del disipador de calor con el ventilador hacia arriba para extraerlo.
-[* blue] Unscrew the four (4) screws from the heat sink.
-[* red] Unscrew the one (1) screw from the fan.
-[* black] Pull the heat sink with the fan upward to remove.
+[* red] Unscrew the four PH1 screws from the heatsink.
+[* orange] You may also need to remove the screw on the fan shroud.
+[* black] Pull the heatsink and the fan upward to remove both.
