Saltar al contenido principal
Desmontaje de Dell Vostro V13
Inglés
Español
Paso 4
Dell Vostro V13 Disassembly: paso 0, imagen 1 de 2 Dell Vostro V13 Disassembly: paso 0, imagen 2 de 2
  • Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
  • Unclip and remove the ribbon from the panel.
  • Always be careful when removing ribbon cables! Try not to bend them unnecessarily. Do not pull them with excess force.
Con una herramienta de abertura de plástico, abra el panel superior, con el interruptor de alimentación, comenzando con el borde inferior derecho más cerca del teclado.
Suelte y retire la cinta del panel.
¡Siempre tenga cuidado al quitar cintas! Intente no doblarlos innecesariamente y tire de ellos con demasiada fuerza.
-[* blue] Using a plastic opening tool, pry open the top panel, with the power switch, starting with the right bottom edge closer to the keyboard.
-[* blue] Unclip and remove the ribbon from the panel.
-[* icon_caution] Always be careful when removing ribbons! Try not to unnecessarily bend them and pull them with excess force!
+[* red] Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
+[* orange] Unclip and remove the ribbon from the panel.
+ [* icon_caution] Always be careful when removing ribbon cables! Try not to bend them unnecessarily. Do not pull them with excess force.
