Saltar al contenido principal
iPad Air 3 Teardown
Inglés
Holandés
Paso 4
iPad Air 3 Teardown: paso 0, imagen 1 de 3 iPad Air 3 Teardown: paso 0, imagen 2 de 3 iPad Air 3 Teardown: paso 0, imagen 3 de 3
  • Safety first! This battery disconnection is definitely not as foolproof as the bracket in the iPad Mini 5.
  • To protect yourself and your device, the battery should be disconnected as soon as possible. In this case, the connector is trapped under the logic board, so it needs a little help from a friend.
  • It feels like the display cables are just too short to easily free the cable bracket, making for a thrilling balancing/unscrewing act.
  • The dual-celled 30.8 Wh battery is a little bigger than the 30.2 Wh Apple promised, taking after the 10.5" Pro, and a big upgrade from the 27.6 Wh battery in the Air 2.
  • If only it had also inherited the highly-coveted stretch-release adhesive pull tabs ... sigh.
Insertar traducción aquí
