Saltar al contenido principal
Asus G53JW-A1 Trackpad Plate Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Asus G53JW-A1 Trackpad Plate Replacement: paso 0, imagen 1 de 3 Asus G53JW-A1 Trackpad Plate Replacement: paso 0, imagen 2 de 3 Asus G53JW-A1 Trackpad Plate Replacement: paso 0, imagen 3 de 3
  • Locate the 1.5 x 7mm Phillips #00 screw at the bottom right of the keyboard housing.
  • Remove this screw. Note that this is the only 1.5x7 mm screw in the entire laptop, so it is very important to keep track of it.
  • Place a screwdriver or other firm tool with a fine tip inside the hole to the left of the screw hole. Push all the way to the left to unlock the slide.
  • It will take a good bit of force to move the slide, as it unlocks a series of clips underneath the trackpad plate.
Insertar traducción aquí
