Saltar al contenido principal
Canon PowerShot S100 Lens Assembly Replacement
Inglés
Holandés
Paso 19
Canon PowerShot S100 Lens Assembly Replacement, Optional: Install CCD on Replacement Lens Assembly: paso 0, imagen 1 de 3 Canon PowerShot S100 Lens Assembly Replacement, Optional: Install CCD on Replacement Lens Assembly: paso 0, imagen 2 de 3 Canon PowerShot S100 Lens Assembly Replacement, Optional: Install CCD on Replacement Lens Assembly: paso 0, imagen 3 de 3
  • If your replacement lens assembly does not include a CCD (sensor), you can swap the CCD from the old lens assembly to the new one.
  • Carefully scrape 5 glue dots from edges of CCD on old lens assembly.
  • Remove 3 screws securing CCD to back of lens assembly and remove CCD, noting any tiny brass washers/spacers that may be present where screws were. Remove CCD, being careful not to touch or get dust on sensor surface.
  • Carefully remove rubber infrared filter gasket and infrared filter (small rectangle of bluish glass) from back of old lens assembly & install on back of new lens assembly.
  • Install CCD on back of new lens assembly (may or may not need to use brass washers to get alignment right for correct focus).
  • Note: S100 & S110 CCDs are not interchangeable - ribbon connector for the S100 lens assembly is larger, & does not fit on the S110 board connector.
Insertar traducción aquí
