iRobot Roomba 870 Battery Replacement
Introducción
Ir al paso 1This guide will teach you how to access, remove, and replace your iRobot Roomba 870 battery.
Qué necesitas
Herramientas
To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
Follow the steps in reverse order for reassembly.
2 personas más completaron esta guía.
