Saltar al contenido principal
iRobot Roomba 690 Drive Wheels Replacement
John Galvin
John Galvin y otro contribuidor
Última actualización: May 11, 2022
5 minuto
Fácil
Introducción
Ir al paso 1
This guide explains how to remove the modular drive wheels for the iRobot Roomba 690 so that they can be more easily cleaned or replaced. Over time hair or other debris may get caught in the wheels of your Roomba. This can lead to the wheels being limited or unable to perform. In some extreme circumstances, the wheel may not be functional for other reasons, requiring replacement. This task is not considered difficult, but it should be known that attempting to remove this component when the battery is still connected to the Roomba can be dangerous, and as such, this guide also explains how to remove the battery during the replacement process. Also, this task does not always need to be performed when debris are caught in the wheels, as it can often be done without disassembly.
Qué necesitas
Herramientas
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: paso 1, imagen 1 de 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 1 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 2 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 2, imagen 3 de 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: paso 4, imagen 1 de 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 1 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 2 de 3 iRobot Roomba 690 Drive Wheels Replacement: paso 5, imagen 3 de 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: paso 6, imagen 1 de 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: paso 6, imagen 2 de 2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
Conclusión
John Galvin
Miembro Desde 03/23/22
584 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Botvin Spring 2022 Miembro de UMass Dartmouth, Team 1-1, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G1
Miembros de 2
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 553
