Saltar al contenido principal
Zoomer Dino Boomer Nose Sensor Replacement
Lauren Mannix
Lauren Mannix y 3 otros contribuidores
Última actualización: May 7, 2024
5 - 10 minutos
Moderado
Introducción
Ir al paso 1
Before removing and replacing the sensor of Zoomer Dino Boomer, check the Troubleshooting Page to make sure the issue with gesture mode cannot be fixed without removing the sensor.
Qué necesitas
Herramientas
Ver más…
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: paso 1, imagen 1 de 2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: paso 1, imagen 2 de 2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: paso 2, imagen 1 de 2 Zoomer Dino Boomer Nose Sensor Replacement: paso 2, imagen 2 de 2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: paso 3, imagen 1 de 2 Zoomer Dino Boomer Nose Sensor Replacement: paso 3, imagen 2 de 2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: paso 4, imagen 1 de 2 Zoomer Dino Boomer Nose Sensor Replacement: paso 4, imagen 2 de 2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: paso 5, imagen 1 de 3 Zoomer Dino Boomer Nose Sensor Replacement: paso 5, imagen 2 de 3 Zoomer Dino Boomer Nose Sensor Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: paso 6, imagen 1 de 1
    • Remove and replace the nose sensor.
Conclusión
Lauren Mannix
Miembro Desde 08/29/15
398 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 16-1, Wollert Fall 2015 Miembro de USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 1,442
