Saltar al contenido principal
Teenage Engineering OP-Z Volume Potentiometer Replacement
Tobias Isakeit
Tobias Isakeit y 3 otros contribuidores
Última actualización: May 7, 2024
45 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
Use this guide to replace the volume potentiometer of your OP-Z.
In case the defect was caused by a drop then the volume knob was probably damaged too. This guide will also show how to replace the knob which can be purchased separately.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: paso 1, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: paso 1, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: paso 1, imagen 3 de 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 2, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 2, imagen 2 de 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 3, imagen 1 de 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: paso 4, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: paso 4, imagen 2 de 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 5, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 5, imagen 2 de 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: paso 6, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: paso 6, imagen 2 de 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 7, imagen 1 de 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: paso 8, imagen 1 de 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 9, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 9, imagen 2 de 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 10, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 10, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 10, imagen 3 de 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 11, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: paso 12, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: paso 12, imagen 2 de 2
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 13, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 13, imagen 2 de 2
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 14, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 14, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 14, imagen 3 de 3
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 15, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 15, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 15, imagen 3 de 3
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 16, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 16, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 16, imagen 3 de 3
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 17, imagen 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 17, imagen 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 17, imagen 3 de 3
    • Peel the highway flex cable off the midframe and remove it.
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: paso 18, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: paso 18, imagen 2 de 2
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 19, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 19, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 20, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 20, imagen 2 de 2
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 21, imagen 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 21, imagen 2 de 2
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: paso 22, imagen 1 de 1
    • Remove the volume potentiometer.
Conclusión
Tobias Isakeit
Miembro Desde 03/31/14
123,979 Reputación
189 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,318
