Saltar al contenido principal
Shark ION Robot 750 Motor Replacement
corieon downing
corieon downing y 2 otros contribuidores
Última actualización: December 27, 2023
30 minuto
Moderado
Necesita más imágenes
Pasos faltantes
Introducción
Ir al paso 1
Your SHARK ION Robot Vacuum 750 has a nice and clean main brush, yet fails to clean the dirt along the way. You notice that the brush doesn't rotate appropriately. This malfunction may be due to the damage to the main brush motor inside. The tools requisite for this operation include a TORX T6 Screwdriver, a TORX T15 Screwdriver, and a Flathead #4 Screwdriver. You may want to check out our Outer Shell Replacement Guide to open up the internal parts.
Qué necesitas
Herramientas
Ver más…
  1. Shark ION Robot 750 Motor Replacement, Outer Shell: paso 1, imagen 1 de 3 Shark ION Robot 750 Motor Replacement, Outer Shell: paso 1, imagen 2 de 3 Shark ION Robot 750 Motor Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Motor Replacement: paso 2, imagen 1 de 2 Shark ION Robot 750 Motor Replacement: paso 2, imagen 2 de 2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Motor Replacement: paso 3, imagen 1 de 2 Shark ION Robot 750 Motor Replacement: paso 3, imagen 2 de 2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Motor Replacement: paso 4, imagen 1 de 2 Shark ION Robot 750 Motor Replacement: paso 4, imagen 2 de 2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Motor Replacement: paso 5, imagen 1 de 3 Shark ION Robot 750 Motor Replacement: paso 5, imagen 2 de 3 Shark ION Robot 750 Motor Replacement: paso 5, imagen 3 de 3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Motor Replacement: paso 6, imagen 1 de 1
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Motor Replacement, Motor: paso 7, imagen 1 de 2 Shark ION Robot 750 Motor Replacement, Motor: paso 7, imagen 2 de 2
    • Be sure to disconnect any source of power related to your vacuum for safety purposes.
    • Remove the bolt to detach the motor by using the Phillips #0 screwdriver.
    • The motor is connected to the motherboard by this group of wires. Gently pull on the white plug to disconnect the wires.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 388
