Saltar al contenido principal
Shark ION Robot 750 Outer Shell Replacement
Qué necesitas
  1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: paso 1, imagen 1 de 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: paso 1, imagen 2 de 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Outer Shell Replacement: paso 2, imagen 1 de 2 Shark ION Robot 750 Outer Shell Replacement: paso 2, imagen 2 de 2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Outer Shell Replacement: paso 3, imagen 1 de 2 Shark ION Robot 750 Outer Shell Replacement: paso 3, imagen 2 de 2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Outer Shell Replacement: paso 4, imagen 1 de 2 Shark ION Robot 750 Outer Shell Replacement: paso 4, imagen 2 de 2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Outer Shell Replacement: paso 5, imagen 1 de 3 Shark ION Robot 750 Outer Shell Replacement: paso 5, imagen 2 de 3 Shark ION Robot 750 Outer Shell Replacement: paso 5, imagen 3 de 3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Outer Shell Replacement: paso 6, imagen 1 de 1
    • Lift the outer shell to expose the Shark’s interior.
Conclusión
Youness Elfath
Miembro Desde 09/13/23
183 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 133
