Nikon Coolpix P90 Memory Card Replacement
Introducción
Ir al paso 1The Nikon Coolpix P90 is only compatible with SD and SDHC memory cards. It is not compatible with Multi Media Cards (MMC).
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
Gently push the memory card down into the compartment until it clicks to unlock.
Release and pull memory card out with your fingers.
