Saltar al contenido principal
Nikon Coolpix P90 Flash Bulb Replacement
Elizabeth Kamine
Elizabeth Kamine y 8 otros contribuidores
Última actualización: January 9, 2025
40 - 50 minutos
Difícil
Imágenes Inconsistentes
Necesita más imágenes
Introducción
Ir al paso 1
The Nikon Coolpix P90 is a high-quality compact digicam with a magic zoom. It was originally released in 2009 and is now archived by Nikon. Unfortunately, the camera’s flash may wear out or break due to mini-cracks in the flash tubes, exploding bulbs, or other wear and tear. If your Nikon Coolpix P90 flash does not fire correctly, it is most likely time to replace the flash bulb.
This repair requires you to remove the solder connecting the wires to the light bulb. Desoldering the wires is the most involved task of this repair, but iFixit believes in you. For additional support, follow the IFixit soldering instructions to avoid burning yourself or damaging the camera.
Qué necesitas
Herramientas
Ver más…
  1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: paso 1, imagen 1 de 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: paso 1, imagen 2 de 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: paso 1, imagen 3 de 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: paso 2, imagen 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: paso 2, imagen 2 de 2
    • Press the button on the side of the body to open the flash compartment.
  3. Nikon Coolpix P90 Flash Bulb Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the compartment.
  4. Nikon Coolpix P90 Flash Bulb Replacement: paso 4, imagen 1 de 1
    • Place the plastic opening tool along the crack on the side of the flash compartment cover and pry open and detach the cover.
  5. Nikon Coolpix P90 Flash Bulb Replacement: paso 5, imagen 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
    • Detach the plastic cover.
  6. Nikon Coolpix P90 Flash Bulb Replacement: paso 6, imagen 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement: paso 6, imagen 2 de 2
    • Carefully remove the flash bulb holder with your fingers.
  7. Nikon Coolpix P90 Flash Bulb Replacement: paso 7, imagen 1 de 1
    • Using the plastic opening tool, pry the metal bulb frame out of the socket.
  8. Nikon Coolpix P90 Flash Bulb Replacement: paso 8, imagen 1 de 1
    • Remove the plastic stoppers on either side of the metal flash bulb tray.
  9. Nikon Coolpix P90 Flash Bulb Replacement: paso 9, imagen 1 de 1
    • Using a soldering iron, desolder each of the wires connected to the light bulb.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
Conclusión
Equipo
Cal Poly, Team 20-14, Maness Winter 2015 Miembro de Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 879
