Saltar al contenido principal
LG K20 PLUS Volume Buttons Replacement
Patrick
Patrick y otro contribuidor
Última actualización: December 6, 2021
Sin estimación
Moderado
Guía aportada por comunidad
Qué necesitas
Herramientas
Ver más…
  1. LG K20 PLUS Volume Buttons Replacement, Remove the back cover and battery: paso 1, imagen 1 de 2 LG K20 PLUS Volume Buttons Replacement, Remove the back cover and battery: paso 1, imagen 2 de 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Volume Buttons Replacement, Midframe: paso 2, imagen 1 de 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Volume Buttons Replacement: paso 3, imagen 1 de 2 LG K20 PLUS Volume Buttons Replacement: paso 3, imagen 2 de 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Volume Buttons Replacement, Rear-Facing Camera: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Volume Buttons Replacement, Motherboard Removal: paso 5, imagen 1 de 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Volume Buttons Replacement, Volume Buttons Removal: paso 6, imagen 1 de 1
    • The volume button assembly is held onto the frame with fragile plastic tabs.
    • Use the tip of a spudger or similar tool to gently pry the plastic tabs upwards and outwards.
Conclusión
Una persona más ha completado esta guía.
Patrick
Miembro Desde 05/14/14
6,586 Reputación
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 987
