KK-82MS-B Battery Replacement
Introducción
Ir al paso 1Signs you may need this replacement:
- The device doesn't turn on
- The display appears faded/weak
This is a difficult replacement. You will need to break some things during this replacement permanently. Be aware there is a high risk of battery puncture during this replacement. Proceed at your own risk.
Qué necesitas
Unscrew the back and open the calculator like a book. Open it carefully so you don't tear the battery wires.
Lift and remove both wires connected to the battery. They are blue.
Insert your new batteries into the same spot as the previous ones.
Slide the blue wires back into place.
