Saltar al contenido principal
Huawei Honor 8 Rear Camera Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch y 3 otros contribuidores
Última actualización: May 7, 2024
30 - 45 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to remove and replace a broken or defective rear camera in the Huawei Honor 8.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Huawei Honor 8 Rear Camera Replacement, Rear Glass: paso 1, imagen 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 8 Rear Camera Replacement: paso 2, imagen 1 de 3 Huawei Honor 8 Rear Camera Replacement: paso 2, imagen 2 de 3 Huawei Honor 8 Rear Camera Replacement: paso 2, imagen 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • Lift the rear glass with the suction cup to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei Honor 8 Rear Camera Replacement: paso 3, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 3, imagen 2 de 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 8 Rear Camera Replacement: paso 4, imagen 1 de 3 Huawei Honor 8 Rear Camera Replacement: paso 4, imagen 2 de 3 Huawei Honor 8 Rear Camera Replacement: paso 4, imagen 3 de 3
    • The fingerprint cable is located above the power and volume buttons on this side of the phone. Only use the tip of the opening pick in this area to avoid damage.
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 8 Rear Camera Replacement: paso 5, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 5, imagen 2 de 2
    • If the adhesive gets hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 8 Rear Camera Replacement: paso 6, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 6, imagen 2 de 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • The fingerprint cable is still connected to the motherboard. Don't try to remove the rear glass all the way yet.
  7. Huawei Honor 8 Rear Camera Replacement: paso 7, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 7, imagen 2 de 2
    • Carefully lift the rear glass and fold it to the left side of the Honor 8.
  8. Huawei Honor 8 Rear Camera Replacement: paso 8, imagen 1 de 1
    • Remove the Phillips #00 screw (2.8 mm length) that secures the metal bracket on top of the fingerprint flex connector.
  9. Huawei Honor 8 Rear Camera Replacement: paso 9, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to remove the metal bracket that sits on top of the fingerprint and display flex connectors.
  10. Huawei Honor 8 Rear Camera Replacement: paso 10, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 10, imagen 2 de 2
    • Use a spudger to pry up and disconnect the fingerprint flex connector.
  11. Huawei Honor 8 Rear Camera Replacement, Midframe Bezel: paso 11, imagen 1 de 1
    • Remove these Phillips #00 screws securing the midframe bezel:
    • Eight screws with 3.5 mm length
    • Eight screws with 2.9 mm length
    • Some screws might be covered with a tamper proof sticker.
  12. Huawei Honor 8 Rear Camera Replacement: paso 12, imagen 1 de 3 Huawei Honor 8 Rear Camera Replacement: paso 12, imagen 2 de 3 Huawei Honor 8 Rear Camera Replacement: paso 12, imagen 3 de 3
    • Insert an opening pick underneath the top right edge of the midframe bezel.
    • Use the opening pick to pry up the midframe bezel.
    • Insert the opening pick underneath the bottom left corner of the bezel and pry it up.
  13. Huawei Honor 8 Rear Camera Replacement: paso 13, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 13, imagen 2 de 2
    • Insert the long edge of an opening pick in the seam between the midframe and the bezel on the left side of the phone.
    • Slide the opening pick along the left side of the phone to cut the adhesive underneath the midframe bezel.
  14. Huawei Honor 8 Rear Camera Replacement: paso 14, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 14, imagen 2 de 2
    • Repeat the procedure on the right edge of the phone to cut the adhesive underneath the midframe bezel.
  15. Huawei Honor 8 Rear Camera Replacement: paso 15, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 15, imagen 2 de 2
    • Carefully grasp the midframe bezel from the bottom corners and lift it upwards.
    • Remove the midframe bezel.
  16. Huawei Honor 8 Rear Camera Replacement, Battery Disconnect: paso 16, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement, Battery Disconnect: paso 16, imagen 2 de 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  17. Huawei Honor 8 Rear Camera Replacement, Rear Camera: paso 17, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement, Rear Camera: paso 17, imagen 2 de 2
    • Use a spudger to pry up and disconnect the rear camera flex cable from its motherboard socket.
  18. Huawei Honor 8 Rear Camera Replacement: paso 18, imagen 1 de 2 Huawei Honor 8 Rear Camera Replacement: paso 18, imagen 2 de 2
    • Use a pair of tweezers to carefully lift the rear camera out of its recess and remove it.
Conclusión
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Una persona más ha completado esta guía.
Miembro Desde 11/23/16
229,471 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,454 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 10
Todo El Tiempo: 659
