Saltar al contenido principal
Huawei Honor 10 Rear Cameras Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch y 4 otros contribuidores
Última actualización: May 7, 2024
30 - 40 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to remove and replace broken or defective rear cameras in the Huawei Honor 10.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Herramientas
Ver más…
  1. Huawei Honor 10 Rear Cameras Replacement, Rear Glass: paso 1, imagen 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Rear Cameras Replacement: paso 2, imagen 1 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 2, imagen 2 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 2, imagen 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Rear Cameras Replacement: paso 3, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 3, imagen 2 de 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Rear Cameras Replacement: paso 4, imagen 1 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 4, imagen 2 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 4, imagen 3 de 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Rear Cameras Replacement: paso 5, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 5, imagen 2 de 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Rear Cameras Replacement: paso 6, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 6, imagen 2 de 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: paso 7, imagen 1 de 3 Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: paso 7, imagen 2 de 3 Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: paso 7, imagen 3 de 3
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Huawei Honor 10 Rear Cameras Replacement: paso 8, imagen 1 de 1
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Huawei Honor 10 Rear Cameras Replacement: paso 9, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Huawei Honor 10 Rear Cameras Replacement: paso 10, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 10, imagen 2 de 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Huawei Honor 10 Rear Cameras Replacement, Motherboard Cover: paso 11, imagen 1 de 1
    • Remove the six Phillips screws securing the motherboard cover:
    • Four 3.4 mm long screws
    • Two 2.9 mm long screws
  12. Huawei Honor 10 Rear Cameras Replacement: paso 12, imagen 1 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 12, imagen 2 de 3 Huawei Honor 10 Rear Cameras Replacement: paso 12, imagen 3 de 3
    • Slide an opening pick under the motherboard cover next to the cameras and carefully pry it up by twisting the opening pick sideways.
    • Repeat the previous process on the opposite side of the motherboard cover until the cover pops out.
    • Remove the motherboard cover.
  13. Huawei Honor 10 Rear Cameras Replacement, Rear Cameras: paso 13, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement, Rear Cameras: paso 13, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the flex cable for the rear cameras.
  14. Huawei Honor 10 Rear Cameras Replacement: paso 14, imagen 1 de 2 Huawei Honor 10 Rear Cameras Replacement: paso 14, imagen 2 de 2
    • Use a pair of tweezers to remove the rear cameras.
Conclusión
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Miembro Desde 11/23/16
229,601 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,470 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 36
Todo El Tiempo: 815
