How to open the USB Rubber Ducky
Introducción
Ir al paso 1The USB Rubber Ducky is a powerful hacking tool, but to modify or repair it, you'll need to open the case.
In this guide, we'll show you how to safely open the case of your USB Rubber Ducky.
Qué necesitas
Herramientas
First remove the the USB-C cap
Jam a flat object, such as your fingernail or a small screwdriver, in between the metal sheath and the Ducky on both sides.
Remove the metal sheath by pulling it off the Ducky.
Herramienta utilizada en este paso:iFixit Opening Picks (Set of 6)$4.99
Carefully separate the top and bottom plastics by inserting a plastic pick at the seam.
Una persona más ha completado esta guía.
