Saltar al contenido principal
How to Open the Fitbit Charge 2
Adriana Zwink
Adriana Zwink y otro contribuidor
Última actualización: May 24, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to open your Fitbit Charge 2 for repairs.
Qué necesitas
Herramientas
  • iOpener
    iOpener
  • iSesamo Opening Tool
  • Spudger
    Spudger
Ver más…
  1. How to Open the Fitbit Charge 2, Remove the watch band: paso 1, imagen 1 de 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: paso 2, imagen 1 de 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: paso 3, imagen 1 de 3 How to Open the Fitbit Charge 2, Slide along the left edge: paso 3, imagen 2 de 3 How to Open the Fitbit Charge 2, Slide along the left edge: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: paso 4, imagen 1 de 2 How to Open the Fitbit Charge 2, Slide along the bottom edge: paso 4, imagen 2 de 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: paso 5, imagen 1 de 3 How to Open the Fitbit Charge 2: paso 5, imagen 2 de 3 How to Open the Fitbit Charge 2: paso 5, imagen 3 de 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: paso 6, imagen 1 de 2 How to Open the Fitbit Charge 2: paso 6, imagen 2 de 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: paso 7, imagen 1 de 2 How to Open the Fitbit Charge 2: paso 7, imagen 2 de 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: paso 8, imagen 1 de 2 How to Open the Fitbit Charge 2: paso 8, imagen 2 de 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: paso 9, imagen 1 de 2 How to Open the Fitbit Charge 2: paso 9, imagen 2 de 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: paso 10, imagen 1 de 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
Conclusión
Opening didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Miembro Desde 12/18/19
56,393 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,465 Guías creadas
Un comentario
How do I get the daughterboard out?
Pospesel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 59
Todo El Tiempo: 5,886
