Saltar al contenido principal
HP Pavilion 15-ay041wm Optical Disc Drive Replacement
Kristen Gismondi
Kristen Gismondi y 3 otros contribuidores
Última actualización: July 11, 2024
5 - 10 minutos
Moderado
Introducción
Ir al paso 1
This guide will show you how to replace the optical disc drive in your HP Pavilion 15-ay041wm. This could help if the CD drive is no longer working, giving you issues with opening and retracting, getting an error message. Be careful when removing parts as the metal pieces can be sharp and can cause a possible injury.
Qué necesitas
Herramientas
  1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 2, imagen 2 de 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 3, imagen 3 de 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Disc Drive: paso 4, imagen 1 de 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: paso 5, imagen 3 de 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
92,209 Reputación
241 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
119 Miembros
19,481 Guías creadas
Un comentario
Might add “Optical” to drive title to save some confusion.
mike - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 22
Todo El Tiempo: 666
