HP Envy x360 m6-aq103dx Hard drive Replacement
Introducción
Ir al paso 1Is the hard drive on you HP Envy x360 m6-aq103dx acting up or not working correctly? Follow this simple guide to replace the hard drive. You'll need a plastic opening tool and a Phillips Head #1 screwdriver.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
5 personas más completaron esta guía.
