Saltar al contenido principal
HP Envy x360 15m-bp112dx Fan Replacement
Cameron Anderson
Cameron Anderson y 2 otros contribuidores
Última actualización: June 1, 2023
7 minuto
Moderado
Introducción
Ir al paso 1
Use this guide to replace the fan for the HP Envy x360 15m-bp112dx. The fan is used to cool down the computer components, as overheating causes major issues. Some reasons to remove or replace the fan include the fan not working, the fan is unable to cool down the system due to to reduced speed from particles lodged in the fan, and the fan is making noise.
Qué necesitas
Herramientas
  1. HP Envy x360 15m-bp112dx Fan Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Fan Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 2, imagen 3 de 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Fan Replacement: paso 3, imagen 1 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 3, imagen 2 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 3, imagen 3 de 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Fan Replacement: paso 4, imagen 1 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 4, imagen 2 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 4, imagen 3 de 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Fan Replacement: paso 5, imagen 1 de 2 HP Envy x360 15m-bp112dx Fan Replacement: paso 5, imagen 2 de 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Fan Replacement, Fan: paso 6, imagen 1 de 2 HP Envy x360 15m-bp112dx Fan Replacement, Fan: paso 6, imagen 2 de 2
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Fan Replacement: paso 7, imagen 1 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 7, imagen 2 de 3 HP Envy x360 15m-bp112dx Fan Replacement: paso 7, imagen 3 de 3
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Fan Replacement: paso 8, imagen 1 de 2 HP Envy x360 15m-bp112dx Fan Replacement: paso 8, imagen 2 de 2
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
Conclusión
Equipo
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Miembro de UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
Miembros de 4
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 174
