Saltar al contenido principal
HP Envy x360 15m-bp111dx Hard Drive Replacement
Ross Snead
Ross Snead y 5 otros contribuidores
Última actualización: November 23, 2022
15 - 30 minutos
Fácil
Introducción
Ir al paso 1
This guide will assist in locating, removing, and replacing the hard drive of your HP Envy x360 15m-bp111dx. You may need to utilize this guide if your laptop is displaying a warning message concerning the hard drive or the computer does not boot up.
Be sure that your laptop is powered off, you're disconnected from the power adapter, and that the components have cooled before beginning this replacement.
For more troubleshooting information for the Hard Drive, follow the instructions on the troubleshooting page.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 2, imagen 3 de 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: paso 3, imagen 1 de 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: paso 3, imagen 2 de 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 4, imagen 1 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 4, imagen 2 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 4, imagen 3 de 3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • The hard drive bay is located in the lower left corner of the computer.
    • The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
  6. HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 6, imagen 1 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 6, imagen 2 de 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 6, imagen 3 de 3
    • Pull the rubber casing away from the drive (not pictured here) and gently lift the hard drive out of the computer.
    • Unplug the drive from power by grabbing the SATA / power cable on the plastic edge and pulling it away from the drive.
    • Do not disconnect the ribbon cable from the motherboard.
  7. HP Envy x360 15m-bp111dx Hard Drive Replacement: paso 7, imagen 1 de 1
    • The hard drive is now removed and can be replaced.
Conclusión
Ross Snead
Miembro Desde 02/22/22
162 Reputación
1 Guía escrita
Equipo
Clemson, Team 2-2, Hunter Spring 2022 Miembro de Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 24
Todo El Tiempo: 522
